both negitive wires together on the amps ?
Both negative input terminals on the amps.
Run "jumpers" from negative terminals on master amp to negative terminals on slave.
Yes Joe that's correct.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
yes thats right Joe but use both negitives on master to both negitives on slave like ^ he said.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
You tried to help, yet ended up asking more questions than OP. If you don't know, don't tell considering these are a couple of high dollar amplifiers, leave it to those who own them, or work with them.
:peepwall:
1. Use the Slave wire type needed
2. Set one to Master, one to Slave
3. Set all gains/filters/etc on the MASTER, leave all Slaves FLAT
4. Connect RCAs to the Master amp, NOTHING to the Slave
5. On the inputs(for leads) connect both amps NEGATIVES together with a jumper
6. The MASTER positives will go to the subwoofers positive, the SLAVE positives will go to the subwoofers negative
7. Wire up the subs like if there was only 1 set of inputs (pos being Master, Neg being slave)
*Total ohm load shown by DMM on subs will be double of what the amps see. (ex. total load of 4 ohms, each amp sees 2 ohms.)
Hope this helped.
EDIT
The Blue and Green wires are jumpers. This is series each to 2 ohms each sub, then series 2 subs together to get 4 ohms, then parallel the two pairs to get 2 ohm final load aka 1 ohm each amp aka 10k rms.
If it were me^^, I would use bolt terminals. So 2 ohm strapped 1 ohm per amp, I would Series each coil, then parallel each pair. Then series them back up to 2 ohms run 1 set of wires to the amps.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
You tried to help, yet ended up asking more questions than OP. If you don't know, don't tell considering these are a couple of high dollar amplifiers, leave it to those who own them, or work with them.:peepwall:
:orly3:
  • Who's Online   0 Members, 0 Anonymous, 1202 Guests (See full list)
