MIKE-2U Posted January 5, 2012 Report Posted January 5, 2012 just as i finshed my diagram 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
Maticus Posted January 5, 2012 Report Posted January 5, 2012 So then Run a - from the top 2 to the slave and a + from the bottom 2 to the master? like this this one will work. Those coils are still in opposite phase. The positive goes from one coil to the negative on the other with a jumper, that will make the coils go in opposite phases, unless there's something in the mess of a picture I'm missing.
LoudNLow931 Posted January 5, 2012 Author Report Posted January 5, 2012 So then Run a - from the top 2 to the slave and a + from the bottom 2 to the master? like this this one will work. Those coils are still in opposite phase. The positive goes from one coil to the negative on the other with a jumper, that will make the coils go in opposite phases, unless there's something in the mess of a picture I'm missing. Your talking about the blue wire connecting the positive and negative on each sub right? That doubles the impedance of the sub, so if its a dual 1 sub that makes it 2ohm. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
Maticus Posted January 5, 2012 Report Posted January 5, 2012 So then Run a - from the top 2 to the slave and a + from the bottom 2 to the master? like this this one will work. Those coils are still in opposite phase. The positive goes from one coil to the negative on the other with a jumper, that will make the coils go in opposite phases, unless there's something in the mess of a picture I'm missing. Your talking about the blue wire connecting the positive and negative on each sub right? That doubles the impedance of the sub, so if its a dual 1 sub that makes it 2ohm. But the way that looks it's like he's putting the positive from the amp to a positive coil, and to a negative coil, with a JUMPER, no coil in between or anything, that's not right. Those coils woild be trying to go in the opposite direction.
LoudNLow931 Posted January 5, 2012 Author Report Posted January 5, 2012 I don't understand what your saying... Each sub is wired in series, Then the top 2 are wired in parallel and the bottom 2 are wired in parallel then the 2 sets of 2 subs are wired together in parallel. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
ChevyBoy95 Posted January 5, 2012 Report Posted January 5, 2012 So then Run a - from the top 2 to the slave and a + from the bottom 2 to the master? like this this one will work. Those coils are still in opposite phase. The positive goes from one coil to the negative on the other with a jumper, that will make the coils go in opposite phases, unless there's something in the mess of a picture I'm missing. Your talking about the blue wire connecting the positive and negative on each sub right? That doubles the impedance of the sub, so if its a dual 1 sub that makes it 2ohm. But the way that looks it's like he's putting the positive from the amp to a positive coil, and to a negative coil, with a JUMPER, no coil in between or anything, that's not right. Those coils woild be trying to go in the opposite direction. no... jumpers dont swap phase, wiring the negative to the postive ON THE AMP switches the phase aka reverse polarity. edit: i do see a flaw in it i didnt see before though. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
MIKE-2U Posted January 5, 2012 Report Posted January 5, 2012 ***** LET SOMEONE VERIFY THIS IS RIGHT FIRST. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
Maticus Posted January 5, 2012 Report Posted January 5, 2012 I don't understand what your saying... The way this looks, the coils inside the sub will be trying to go opposite ways due to being wired in opposite phase. The positive from the amp, is going to the first positive on the sub, correct? then with a jumper, it's connected to the other coil's negative jumper, so that means that the first coil will be trying to go outwards from the motor, while the other coil will be trying to go towards the motor. since the current will be traveling opposite directions in the first sub's coils, it won't excurt as normal, just vibrate, stink, then finally blow. If anyone else is reading this, and has a better way to explain, please chime in. EDIT: This thread is a mess. I don't think I'll be participating in this anymore, so if you want more info from me,PM me.
MIKE-2U Posted January 5, 2012 Report Posted January 5, 2012 oops didnt mean to post more than once 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
LoudNLow931 Posted January 5, 2012 Author Report Posted January 5, 2012 I get what your saying now, So your saying it should be like this? Anyone else that's posting and your not 100% positive, don't post. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
