Looking for someone thats personaly put in or heard subs on a boat, preferably someone thats heard 15s and 10s on a boat....
My install plans as of right now and already have everything (other then Sub amp)
Polk MM6501 (MoMo Series 6.5 Component set)
Polk DB691 (DB Series 6x9s)
Polk PA660 (4channel amp to run the interiors)
Now this is what im trying to decide....
I have a pair of 15" American Bass Subs 500rms ea but their not marine rated like Polk so they would have to be in a sealed enclosure
and I also have a pair of DB1040dvcs (polk 10" dvc subs roughly 270rms) but they are marine rated and can handle moisture so I could put them into a ported box.
Im really leaning on the 15's... now the question is exactly how should I be mounting them...
Right now my boat is a split window but NO seating up front, this spring me and a few buddies are going to be making it a bow rider.
this is where the subs will be installed... under the seats.... BUT do I mount them at the feet pointing twords eachother... or should I mount them back under the seat about 2' from the opening to get a good resonance shooting INTO the boat or mount them flush to where your feet would be in pass and drivers seat pointing INTO the boat.
I plan on having storage under or behind the front seats.
Any ideas?!?!?!?!?!?!?
Edited by Neal82
Truck
Polk 4x6 Plates
Polk 4x6
Polk PA660 4Channel amp
JVC USB Deck
Wifes Car (under construction)
Polk MoMo 6.5" Components
Polk 6x9s
Polk Pa660 4Channel amp
Still trying to talk her into a sub or 2
Boat (under construction)
Polk 5.25" Components
Polk 6.5" Components
2x American Bass DX15s
Polk PA660 4Channel
2x Polk PA880 Sub Amps (hopefully)
I cant believe theres NOONE on here thats never delt with marine audio.... cmon people :( help me out!!!
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
up :turkey:
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
i have polk MM series and they sound great. I dont know too much about marine audio at all. just make sure that speakers are mairne rateed. and if not then make sure water wont get to em. but in my head it makes sense to kind of try to make a 4th order box in the boat like using boat as box. IDK how bass will travel in open air with force. sure aint like a car
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Yup ALL polk are marine rated anyway...
But i couldnt do the 15s in a 4th order because theyre not marine rated... unless I put the back of the sub into a sealed enclosure and the front of it into a ported enclosure... but somehow that just seams not to effective.... hmmm might have to look into that....
Anyone else have some ideas?
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
wow, im really disapointed.... thought you guys knew your stuff.... cmon.........
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
:turkey:
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
Really? A CAR audio site? You thought we knew all about boat stuff? I mean I know it's related buy a boat is not the same thing as a car.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Pics of boat.... I usually try and hide subs in storage area... bass is non directional and 4th order work great...
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Its not that far off... i just want to know the best box setup...
If you sat a box on the ground in your drive way, wich box would sound the best... yes i will have the sides of the boat for sound to bounce off of... the subs will also have a 2.5-3' tunnel the sound/air will be moving thru before it reaches the open area of the boat. Ive seen alot of pictures of them just being placed into the under part of the seat pointing inwards.. but having 3 kids im not risking that and i dont think that will give the best sound.... just looking for someone with some boat knowledge... and 99% of people that have shops and do car installs have done ATV/Motorcycle/Boat/and everything else.... those are the people im looking for :)
No pics.. its put up for the winter.
4th order still has the rear of the sub ported correct??? The subs are not marine rated unfortunatly... so they will be sealed.
Edited by Neal82
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
