Box building
KenC210
Just wondering if i could get a box design. Max dimensions are LxWxH 24.5x40x18. The height won't matter to much so if you need to adjust it that will be fine. The subs are AQ sd2.5 15's and the box is going in a 07 ford escape. I would like it ported both sub and port up tuned at 36-38hz.
Ok, I assumed the following, driver displacement = .14 cuft per sub, number of drivers = 2 and your height is my depth I went for 20" instead of 18"
Enclosure Specifications:
Fb = 36 Hz
Vb = 6,8 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 24,5 in
External Width = 40 in
External Depth = 20 in
Port Width = 5 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 33 3/4 x 23
Front Internal = 33 x 23
Back = 40 x 23
Left & Right Sides:
Side 1 = 18 1/2 x 23
Side 2 = 17 3/4 x 23
Top & Bottom = 40 x 20
L Port Internal Assembly Parts:
Front to Back = 13 x 23
Extension = 6 1/2 x 23
Check my calculations and let me know if you have any questions.
  • Who's Online   1 Member, 0 Anonymous, 1661 Guests (See full list)
