You have to get a window crank puller tool.
http://m.summitracing.com/parts/WMR-W80646
^^^like that one
2001 chevy cavalier
Rebuild in progress
what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2.
well...as i see the level 6 is compared to a lamborghini.....but a corvette?
i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
You won't be able to see it, but it's there. I thought the same thing when I was taking the door panels out of my cavalier. That tool makes it easy. Your local autoparts store should have one.
2001 chevy cavalier
Rebuild in progress
Wonder if it's like my sister's old neon, get a small towel and with the crank pointed down work the towel up to the part that goes in the door. lift up with a slight shimmy from side to side and pull the handle off. Might work
formerly known as Blue86f150
this sux camel dicks
Trust me, the clip is there its just impossible to see like has already been said. Try Blues trick or go buy the tool. I have a 99 sephia which is the spectras prior model and its the same stupid ass style clip that has been on window cranks for many many years.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
clip is between handle and plastic washer. u take a flat head to separate handle and washer, push the panel in to create room at the crank spot with ur hand, and i use a headunit "key" bent slightly to push one side of the clip off. its enough that the handle comes off yet the clip stays attached to handle so u dont loose it
currently my saturn has all panels off by that method while i deaden everything
http://www.stevemeadedesigns.com/board/topic/130066-kia-spectre-05-install-done-pics-up/#entry1828736 check out the build you all helped me on (:
and
in the video you see where i got the handle off but i messed it up but i finally learned :/
  • Who's Online   0 Members, 0 Anonymous, 1021 Guests (See full list)
