doyletr Posted January 6, 2012 Report Posted January 6, 2012 I have an 07 chevy impala with the factory alt (125 amp). Currently I'm running 2 alpine type-r's and CDT EF-61FG PRO - EuroFrame 6.5" 2 Way Components with MTX Thunder TA5601 amp and Cadence ZRS-1502 amp. I am looking to upgrade my subs, but am not sure how much more my alt can take before I need to replace it with a high output alt. How many watts rms should a 125 amp alternator be able to output and safely power the other car's electronics?
MIKE-2U Posted January 6, 2012 Report Posted January 6, 2012 Your alternator is probaly stressing considering the newer car more electronics. I dont know the equation but im guessing about 50 amps or less are left for your system. I woild do the big 3 replace battery with agm wet cell and if you do upgrade subs then get a h/o alternator 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
TeamHT Posted January 6, 2012 Report Posted January 6, 2012 What would upgrading the subs do? Subs don't pull current, amps do. Your stock alternator wouldn't be stressed off of stock electronics, and should be able to power up to 900 watts safely daily. You have a 600rms amp and a 500rms amp... Like said, upgrade the primary battery and big 3 Tell me...does this smell like chloroform to you?
doyletr Posted January 6, 2012 Author Report Posted January 6, 2012 What would upgrading the subs do? Subs don't pull current, amps do. Your stock alternator wouldn't be stressed off of stock electronics, and should be able to power up to 900 watts safely daily. You have a 600rms amp and a 500rms amp... Like said, upgrade the primary battery and big 3 Sorry I wasn't clear there. I meant upgrading the subs and a new amp to power the new subs. I am not exactly sure how loud I want to go yet.
JohnayyBoyy Posted January 6, 2012 Report Posted January 6, 2012 Your alternator is probaly stressing considering the newer car more electronics. I dont know the equation but im guessing about 50 amps or less are left for your system. I woild do the big 3 replace battery with agm wet cell and if you do upgrade subs then get a h/o alternator
JohnayyBoyy Posted January 6, 2012 Report Posted January 6, 2012 what is the big 3 ?you only said 2 of them
doyletr Posted January 6, 2012 Author Report Posted January 6, 2012 what is the big 3 ?you only said 2 of them big 3 is upgrading the wiring. 0 gauge from alt + to battery +, vehicle chassis to battery -, and engine ground to chassis
