Ok so I have been reading on here about building boxes and how to design ported boxes. so today i designed a box using torres' box tuning calculator and this is what i came up with,
the tuning sheet,
a slightly angled view of the front of the box could look,
and the box from above, the lines are to show how far out the subs will go out,
this is a box for two Rockford Fosgate Punch z 10's. This is my first design that i think is right so any help with changes i should do will be greatly appreciated.
Thanks,
KCowboy620
Edit: oops didn't notice i put forst instead of first in the title
Edited by KCowboy620
!999.5 Volkswagen Jetta
1 Planet Audio BIg Bang 15
Powerbass 1500,1
Looks good but why not use the height oh re front baffle instead of doing that weird port you got.
ok i made the port the height of the front and here is the new tuning sheet,
how does this one look?
Powerbass 1500,1
# of common port walls: 3 (I think). Tuning goes down to 33.16
how is common port walls determined i have never understood what that meant?
if it does have 3 common port walls is it the box good with those numbers
Powerbass 1500,1
the # of common port walls is how many walls of the box is part of the port itself. in the firt image you have 1 i think. on one like this there is 3... aqsdc25153d.png
Edited by fmedina
Well finally got to post this here is how everything looks now
the build sheet
the box from above, note these are not the actual subs i'm using these were just some subs that i found in the google warehouse, if there are ant other changes i should make just let me know
Powerbass 1500,1
Looks really good on the final design. Not sure how much power you're gonna run to those Z's but be careful. They were entry level subs from years ago, so watch how much power you feed to them. The design of the box looks really solid though, you should be impressed.
just as a precautionary measure, i'd put some 3/4" dowel rods going from top to bottom, and side to side. you want as little box flex as you can get (none)
