BFF Larry Posted January 8, 2012 Report Posted January 8, 2012 hello SMDer's, i have a problem that has recently popped up... im getting feedback noises from my mids and highs and subs... when i brake, my speakers make a low "click" noise, only audible if volume is turned up past 15. when rolling the volume knob up anywhere from 0-20, you can hear a "clicking" noise coming from the speakers and subs... when i turn my headlights on, i get a "pop" noise as well from the speakers and subs, but its only when you turn on and off, not continuously. I also get a fain "shhhhhhh" noise from the speakers when no music is playing. i do not get alternator whine from accelerating or idling, but i do get brake noise, which is a "click" noise from the speakers. thank you for taking the time to read my post! larry edit: HU is Pioneer DEH5000ub update: I am now getting alternator whine........ shit Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
SnowDrifter Posted January 8, 2012 Report Posted January 8, 2012 Triple checked all power/ground connections? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Ian01 Posted January 8, 2012 Report Posted January 8, 2012 They make noise eliminators for the "shhhh" you decscribed.. I listened to all the headunits turned up with 0 music and got one that didn't do this and, doesn't no matter what the input is; so I guess I got lucky. Also, when I turn on and off my car (ONLY SOMETIMES), I get a high pitched discharge noise. In another thread I was in this got ruled out as neediing a relay. I haven't gotten around to getting one, but when you find them on sites they describe my issue. I'm sorry this info is sloppy, it's late. and sorrry if you knew about this stuff already. edit: I read somewhere splicing turn-on wires isn't a good idea.. (personally, mine is spliced) ·· YouTube ·· ·· The Ride · The Audio ·· ··· The Toy ···
power5000s Posted January 8, 2012 Report Posted January 8, 2012 Check the power wiring possible relocation for ground loop isolators work to eliminate noise....
Ian01 Posted January 8, 2012 Report Posted January 8, 2012 beatbox found this in my old thread. http://www.amazon.com/Stinger-SGN20-SGN21-Pop-Stopper/dp/B001JQ6O54 power5000s mentioned the correct term for the "shhh" problem. ·· YouTube ·· ·· The Ride · The Audio ·· ··· The Toy ···
MIKE-2U Posted January 8, 2012 Report Posted January 8, 2012 is your rca cable run next to power wire ? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
BFF Larry Posted January 9, 2012 Author Report Posted January 9, 2012 thanks everyone for all the replies, @SnowDrifter, ill check my grounds tomoro after classes, @Ian01, its alright, every bit of input and comments help! @power5000s and Ian01, ill look into the ground loop isolators , they are expensive haha is your rca cable run next to power wire ? in the cabin, they are ran separate on each side. but meet up in the back because of the batts and where amp is at... Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
Ian01 Posted January 9, 2012 Report Posted January 9, 2012 @power5000s and Ian01, ill look into the ground loop isolators , they are expensive haha haha yep.. that's why I haven't gotten the 'pop stopper' yet.. but I just got into a better paying job so it's about that time. ·· YouTube ·· ·· The Ride · The Audio ·· ··· The Toy ···
BFF Larry Posted January 10, 2012 Author Report Posted January 10, 2012 i tried grounding my rca on the back of my HU, no luck. i did this because i heard Pioneers have this weird problem after the internal fuse pops. Now im getting alternator whine.... what is going on? should i ground my headunit directly to my bat? Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
mattc3366 Posted January 10, 2012 Report Posted January 10, 2012 I don't think it would hurt to try. Maybe even any ground other than the one from the harness? That's how my deck is grounded. From the back of the radio to a piece of metal behind the dash. Hope this helps! subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch
