911-02r external reg wiring
Truck is 01 Suburban. I have two Mechman rebuilt alts that are setup for an external regulator. I have the 911-02r External Regulator. It has ground, power and field terminals on it. My alts have ground and field....how do I hook this thing up? I was told I need a relay by someone else, which I have a Bosch 5 pin. Just need to know how to hook everything up. BTW I have two alts that need to be wired up to this thing.
Trying to work on it today so any help would be great.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
I have one 250amp mcr ...with transpo reg. And i ran. The field term. To the reg. And the 12+v i put a ring terminal on it and put it on the charging post of the alt and i ran a short ground from the regulator to the firewall near where i mounted the ext. Reg.....and it runs fine no need for a relay .....one problem u might have is one regulator is good for 15amps Max. Not sure if two field wires from your dual alts will be more than the rated 15 amps for one unit...u possibly might need two regulators???.... not sure on the dual alt part
2001 Grand AM
Pioneer UB4000 HU
Tsunami / Monster Wire's
DC POWER INC 260SP ALT w/ XS Power VCM
BIG 3 All 1/0 Monster 400 + YT Under Hood
Stinger SPV70 x2 in Trunk
4x SA-10's On There Way soon i hope
SS XXX-4000D @ .7ohm 3K+
RF Power 4x6's & 6x9's Monsoon Powered
PG TL22 Line Driver
148.7db @ 35-45hz sweep w/ 12" BTL
  • 1 year later...
Does anybody have any better diagrams for this? I also have to wire my alt up for this too. Thank y'allz!
Pontiac Grand Prix GT
400a Mean Machine alt.
EIGHT DD 12''s on a DDz2
DD vo 8''s,6''s,5.25''s&tweets
Norfolk, VA
http://www.youtube.c...ser/ovnorfolkva
https://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishova
http://www.stevemead...__fromsearch__1[/color]
I relay is only necessary if you can't find a solid clean turn on circuit for the regulator.
Assume that the POS terminal on the regulator needs 15 amp capacity. That means you should have a 10 / 12 awg wire that is hot only when the ignition is in the run position. It is also important that this wire does not have any voltage drop in it- the voltage should read more or less exactly the same on the POS terminal of the regulator, as the positive terminal of the battery. The regulator senses voltage from the POS terminal, so if it is lower than the battery voltage from crummy wiring, the alternator(s) will overcharge to compensate. This is why some people run a relay- so they can run a beefy wire straight from the battery terminal, through the relay, to the POS terminal of the regulator with no voltage drop. Then they trigger the relay with some wormy little circuit on the vehicle that is ignition switched. Long story short- use a relay if you can't find an existing ignition switched circuit on the car capable of carrying 15 amps with little or no voltage drop.
also , make sure both alternators have the same output curve, otherwise they will not share the load equally, being run off the same regulator.
Cool thank you MechMan! I did see a vid on YouTube about the installation with the relay, but I was wondering if a relay was necessary! It is hard to find a regular wiring diagram for this!
Norfolk, VA
  • Who's Online   1 Member, 0 Anonymous, 1657 Guests (See full list)
