so i have the part of my trunkthat im going to make a mold of, so i can turn it into a sub box. what i need to know is ,is the masking tape enough so the resin doesnt stick to my trunk or is there something i have to lay down to keep it from sticking to my trunk.
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
I use masking tape first, then I smooth aluminum foil on top,
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
its all metal, no carpet. so would it be enough?and if so i should go aluminum foil? heres what it looks like right now, is it ggod?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
theres card board behind the masking tape on the back n left side to keep shape
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Foil it, then wax the foil....
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) T165.2
(2) T169.3
wax it with wat?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
You can lay down foil on that, and then either use wax, or WD40, coat the foil, then lightly spray trim glue, lay matting, and then resin.
Use about 2-3 layers of matting, let cure completely, the pull the mold, foil and mold should come out nice and easy!
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
wax it with wat?
Spray or paste wax, like you would use to wax your car!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
ok.seems simple enough. now wats trim glue?spray adhesive?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
