meade916 Posted November 30, 2007 Report Posted November 30, 2007 that looks good man, do that. Thats pretty much how all 7 of my batterys are hooked up. Forget the amps, they all have onboard fuses but right AT each positive terminal i always use something that will burn faster then wire (and the car ) i would also ground the back "bank" to the frame and also that front bat to the frame as well as to eachother. Quote All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
t-rob Posted November 30, 2007 Report Posted November 30, 2007 i gotta thank you steve i looked at some of ur pics from when you had the old red ones in and then when you installed the powermasters and i thought thats how you did it.. but one question.. when you ground the back 2 batts, do you ground both seperatly or just run a wire from neg to each then ground? Quote www.myspace.com/trob10 Kenwood eXcelon KDC-x792 Rockford Fosgate Punch 5x7" DC Audio level 3 12" DC Audio 1000.1 Stinger wiring
meade916 Posted November 30, 2007 Report Posted November 30, 2007 i gotta thank you stevei looked at some of ur pics from when you had the old red ones in and then when you installed the powermasters and i thought thats how you did it.. but one question.. when you ground the back 2 batts, do you ground both seperatly or just run a wire from neg to each then ground? i would just connect them together and make the run to the front....now that they are together, just run a single 1/0 from the nearest terminal to a good frame ground and do the same up front. Might be overkill for what you are running but i like overkill When your system grows you are already halfway there if you go over the top when you dont need to Quote All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
t-rob Posted November 30, 2007 Report Posted November 30, 2007 soo fig 1 or fig 2 what one would you do? Quote www.myspace.com/trob10 Kenwood eXcelon KDC-x792 Rockford Fosgate Punch 5x7" DC Audio level 3 12" DC Audio 1000.1 Stinger wiring
CUT BUDDY Posted December 2, 2007 Author Report Posted December 2, 2007 Steve, why use frame grounding? Quote TEAM MechMan Alternators
Derrick824 Posted December 2, 2007 Report Posted December 2, 2007 Steve, why use frame grounding? Might be overkill for what you are running but i like overkill Overkill FTW! Quote
t-rob Posted December 2, 2007 Report Posted December 2, 2007 Steve, why use frame grounding? frame is one of th best possible grounds if not thee best Quote www.myspace.com/trob10 Kenwood eXcelon KDC-x792 Rockford Fosgate Punch 5x7" DC Audio level 3 12" DC Audio 1000.1 Stinger wiring
