Rf Amps Help
t-rob
well i thought i understood why these mono amps had 2 "A and B" channels for wiring speakers up
but now i am confused and was wondering if someone could send me a link, or explain to me how this works
why do they say mono amp but have 2 + and 2 -
how do you wire them to subs..
example t10001bd wired to 1 fi bl
or t10001bd wired to 2 fi ssd's
sorry if this question seems stupid i just cant find anything to teach me
or help me understand
Edited by t-rob
www.myspace.com/trob10
Kenwood eXcelon KDC-x792
Rockford Fosgate Punch 5x7"
DC Audio level 3 12"
DC Audio 1000.1
Stinger wiring
basically the amplifier is internally bridged right guys?
so no matter if you use the positive and negative on one channel or the other it will still act bridged.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
see thats what i thought...
that if you use one side or the other its still gunna give you the rms power..
but then i wa slooking at pics of chodes setup and he has both sides being used...
so how much comes out of each?
DC Audio 1000.1
Stinger wiring
it should be the same eather way, my old mtx 500d was like that, its internally bridged into 2channels just to make it easyer on wireing cause most of the mtx show trucks only use one side of the pos n neg's, it should be the same on each side but if u hooked like 2ohm to a and 2ohm to b it will set the amp to 1ohm, i think chode used it like that for runnin 2 subs, each at 2ohm to the amp makes it alot cleaner looking and easyer to hook up, but whats wierd about my amp is, its internally bridged into 2 channels but u can bridge those 2 channels to i dont get it, its like +speaker1- +speaker2- i dont get it why companys do this b
|______bridge_______|
maby to make it look kewler i dunno or just a more efficent way of hookin em up, hope the answers ur question mayne and good luck with it just make sure that what ohm load u hook to each will step eachother down in the middle like a 4ohm to a and 4ohm to b=2ohm to amp B)
Edited by tacomabanga1986
thanks man
im not actually doing this
im just reading a lot and trying to learn more
but im still slighty confused
so its internaly bridged so
if you use the "A" channel or "b" channel either or not both
you will still be getting the rms out of the amp?
and if you use both how much does each side put out?
DC Audio 1000.1
Stinger wiring
thanks man
whether you use the A or B channel each channel puts out the same rms. let's just say you have two subs with a mono amp ........... you can run one sub on the A channel and one on the B channel, they are bridged to only one channel though. having two speakers inputs on a mono amp just makes it easier to hook up more than one speaker but it's still a one channel(mono) amp though.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i think this is right
the amp is a rf t10001bd if you cant read the writing
and the subs are 2 12" fi ssd Dual 1 ohm
i dont know for sure though is
do you wire the subs in series like in the diagram or in parallel "+to+ -to-" on each sub to get the 2ohm load?
thanks again for the help! I really appreciate it!
Edited by t-rob
DC Audio 1000.1
Stinger wiring
  • Who's Online   1 Member, 0 Anonymous, 1387 Guests (See full list)
