To run at .5 ohm you will need beefy electrical. Be warned however that .5 ohm will void all warranties with most manufacturers and will cause more heat. So be sure if you try it that you can properly feed the amp with electricity and keep it cool.
Current Set-Up
2004 Chevy Tahoe
Subs: 2 DC XL 15's
Box: 8.5 ft^3 @ 38hz
Amp: Amrican Bass VFL 500.1
Alt: Db Electric 250amp
Batts: 2 Kinetic HC 1200s
Radio: Pioneer 3300UB
Doors: Pyle Pro Mids/Goldwood Tweets
Amp: Alpine MRP-300/Hifonics ZX80.4
Wire: Kicker 1/0 Guage
Termlab: 153.1 Outlaw Style @ 46HZ
  • 6 months later...
That amp is plenty powerful at 1 ohm, you shouldn't ever go to under 1 ohm on a Fosgate amp. If you need more that 2400 watts(which I'm sure it birthed out at) get a different amp.
