Cleaning Subwoofers
there is a few great simple stuff to use to clean woofers.
What we used at the speaker shop was (depending on the dome-printed designs-ect)
WD-40 is absolutley awsome on poly/rubber/glossypaper cones/surround/domes
Even with Foam, I still somewhat go over the surround, but dont drench it, just a one over on the surround if its foam.
If you have the chemical laying around, Toulene is the best cleaning liquid for cone stains (poly glossy paper/carbon fiber rubber surrounds)
but again, watch out for the painted domes.
And Armor All also works like the guy up there said ^^^^
wd40 is great on rubber based glues. Basically silicone or rubber based glues. CA, I have no idea. All the speakers I have ever built on the side, or at the factory are rubber based, and wd40 kicks a$$ ... but different companies use different glues, but about 50% use rubber based
