yeah strapped which means each amp was seeing .35 nominal load.. you were using it for reference only reason im putting it out there..and OP what vehicle is this going into?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
OP means original poster.. and im not familiar with dual alt brackets for that vehicle..id shop around for an alt if you havent..someone may make a bigger alternator for you vehicle
power: dd m4
I run saz4500s.. Imo I would try for 300A+ for alt and atleast 3 decent batterys in the back to keep the amp happy
You need power to make power, if ou can properly power your amp it will make about 5-6k depending on how you wire it
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • 2 months later...
I'm on the same boat, just got a saz4500 for two dcxl15s.. I will be only keeping 1 alt and its a 270 amp dcpower and I was told to run 3-4 batts in the back.. I'm looking at the xs xp3000 but they're 3000w while the xs d3100 are 5000w, which is a mighty difference in the end..
2008 TBSS Black Granite
Alpine CDA-117
Clarion EQS746
AudioQue Supertweets @ dash
Alpine DDT-s30 @ b pillars
Alpine SPR-60c @ front doors
Alpine SPR-60 @ rear doors
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Optima YT underhood *temp
Two15DCxls
Hifonics bxi2610 *temp
saz4500 and 4 xp3000s coming soon.
xp3000 will be more or less the same as a d3100 for daily. 3000 actually has 10 more AH, but Nathan said you really wouldn't notice the difference between the two.
3-4 runs in the back? 3 runs of positive from the front bat to the back?
With that alt be about to keep them charged?
I would at least do 2 runs of positive and 2 runs of grounds to the back batts. Like said above I would look for a bigger alt. I know I have seen a 2.5 with a 300amp just can't remember where.
2009 Tahoe
2000bc Cresendo POWA Need 3500
2 Sundown Zv3 18 high rolled sexiness
dual alt bracket with Singer alt(coming soon)
Mtx Q(not sure if I'm going to use)
Knu wire and RCA's
Bass Head Bands
Oh and a few pairs of Jordan's
Thanks 01exsport! I didn't know that.. makes me feel a little more secure about getting the xp3000s and for cheaper.. btw does anyone know the audiosavings/xspower xp battery deadline?
Alpine CDA-117
Clarion EQS746
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Two15DCxls
  • Who's Online   0 Members, 0 Anonymous, 1961 Guests (See full list)
