Never designed a box before
I have most of the spots filled in on the torres calc but I'm not sure what to do with some of them, like the ones in the misc category
Can someone help me out a bit? Sub is an Audioque HDC3 15
Space I'm working with is
41.5" W
41.5" H
25" L
2005 Honda CR-V
AQ HDC315-A
Hifonics BRZ1700.1D .5 Ohm
4.4 ft^3 box
Kenwood Deck
Big 3
XS Power D5100R Starter, D975 Rear
why is your picture different from your specs you typed ? targeted tuning fq, and vehicle i can TRY and help you
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
try 2 6inch aero's...need mo port..like around 12-13 ish per cube
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
The ones I typed are the dimensions of the trunk, and I was aiming at 4 sq feet when I put them in the calculator
I'm aiming for ~35 hz tuning
vehicle is an 05 honda cr-v
You should aim for 14-18 square inches of port per cube
I used this thing to find port dimensions: http://www.diyaudioandvideo.com/Calculator/Box/
To be honest I really don't know what I'm doing with this calculator
2005 Honda CR-V
AQ HDC315-A
4.4 ft^3 box
Kenwood Deck
Big 3
Port area/cu ft would depend on what type of port you're using too. Any ideas if you plan on using a slotted port or aeroport?
A slotted port would be easier but I've heard good things about aero's I guess. Just did some quick searching and it seems to be rather hard to find the right one
2005 Honda CR-V
AQ HDC315-A
4.4 ft^3 box
Kenwood Deck
Big 3
I've never personally done an aeroport but I do hear good things about them as well. I would say that slotted ports are "easier" but as I've never worked with aeroports I can't make that assumption.
well i just got the hang of this program yesterday but this "looks" right. let someone chime in
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
