Go-N-Def Posted January 19, 2012 Report Share Posted January 19, 2012 I just picked up a 2003 ford explorer. It has steering wheel radio controls my wife want to keep. Id like to know if there is a certin haedunit I should look for that would allow me to keep this option or is it a certin item that i can use to keep my wheel controls. Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL Link to comment Share on other sites More sharing options...
bassrace Posted January 19, 2012 Report Share Posted January 19, 2012 It should be in a harness 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
RickyFriery97 Posted January 19, 2012 Report Share Posted January 19, 2012 There's a module that you install and program along with the wiring harness Just make sure you get the correct module 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer Link to comment Share on other sites More sharing options...
Go-N-Def Posted January 19, 2012 Author Report Share Posted January 19, 2012 There's a module that you install and program along with the wiring harness Just make sure you get the correct module Are you saying I could use any headunit? Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL Link to comment Share on other sites More sharing options...
JasonJones Posted January 20, 2012 Report Share Posted January 20, 2012 There's a module that you install and program along with the wiring harness Just make sure you get the correct module Are you saying I could use any headunit? You can use "any" headunit. I prefer Kenwoods because they are the easiest to hookup because they have a steering wheel control wire in the harness. Use the ASWC harness from Axxess(Metra). Setup is straightforward just go to their website and it explains EXACTLY what to hookup and how. I use them all the time and they work pisser. Link to comment Share on other sites More sharing options...
