El1T3Bass Posted January 20, 2012 Report Posted January 20, 2012 Lvl4 xl 18 on 3k. I'll end up putting 4-5k within a year Going in a ext TB Goal is to have a great daily box that can also pull good numbers and move some air! All under the window line Let me know if I should change something! Thanks! wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
pa-pa-platypus Posted January 20, 2012 Report Posted January 20, 2012 in the torres the height should 14.5 instead of 13.75..looks like you have it in the sketchup but not the calculator This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
Guest Posted January 20, 2012 Report Posted January 20, 2012 in the torres the height should 14.5 instead of 13.75..looks like you have it in the sketchup but not the calculator he has it right. baffle is 1.5" thick so you subtract 2.25" from 16 which is 13.75"
El1T3Bass Posted January 20, 2012 Author Report Posted January 20, 2012 He's right I messed up. Here's a new pix. I'll get on Torres soon Torres didn't change, should I stick with 35hz tuning or drop it? Should I have the port on passenger or drivers side? wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
carshateme Posted January 20, 2012 Report Posted January 20, 2012 Are you sure those two 18s are going to fit on the top...looks like from the sketch that it's gonna collide...aka over lap each other when trying to screw them down. Or am I looking at it wrong? (or is that a face plate running flush with the subs?) New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
El1T3Bass Posted January 20, 2012 Author Report Posted January 20, 2012 There should be enough room, hole cutout is like 17 and I can fit 19" iirc wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
Joe X Posted January 20, 2012 Report Posted January 20, 2012 Some vertical crossbraces should be used also.
El1T3Bass Posted January 20, 2012 Author Report Posted January 20, 2012 I have 2" stell rod for vertical, horizontal and port along with resign and mat to fiberglass everything. Also will be adding 45's wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
El1T3Bass Posted January 21, 2012 Author Report Posted January 21, 2012 Bump wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
