Okay so I may be getting two amps soon and might run both to one sub. I know ill have to match AC output of both and will use my DMM for that. My plan is to set both amps with the dd-1 then measure ac output on same 40 Hz tone and match the lower one of the two.
Just confirming if this is the best way to go about this. Amps are identical. They are strappable but only at 2 ohm and woofer is dual 2. In gonna run one amp at 1 ohm daily then chain them together for comps if I'm still running a single woofer setup
Edited by baaudio
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Ya I know read my last section. That's what I'm doing daily. But for comps I wanna run both amps. They're class gh does 2000 @ 1 and 1500 @ 2 so it'd be a gain of 50% power wise.
Team NWSPL
baaudio Build Log
just to be clear, u want to run both amps strapped at 1ohm or each amp on a coil at 2ohm?
1ohm strapped will void most warranties since each amp would see 1/2ohm
Edited by Decaf
set one amp with the DD1. then measure the AC output of that amp. next, set the second amp to that same AC output. now your gains will be matched and safe.
No it would be one coil per amp. That's why I wanna match them. Skittles thanks for the answer. That's what I was thinking would be the right way. I just couldn't say it as clearly. Sorry for the confusion decaf
Team NWSPL
baaudio Build Log
