Need Help Quick.
ok. my buddy has a lanzar amp connected to two audiobahn 12's, i connected the amp and it was running great for about 5 minutes. then he turned off his car and the posetive fuse blew instantly. if you put the fuse back in without the posetive battery connected it goes in fine. but if you connect the posetive lead it blows again. the front blue LED stays lit tho when the car is on.
i am thinking his battery puts out more power then the amp can handle .
we need to figure this out quick because he has to go to work at 3. this is the second amp he has bought so buying a new one is out of the question.
what do you guys think ??
610EUROs
Check ur wire
might be a issue with the power wire grounding out.
Just keep the fuse out till u figure it out man.
Not worth the risk to fuck with on short time.
J
"No poor dumb bastard ever won a war by dying for his country. He did it by making the other poor dumb bastard for his country."
George Patton
ya i have the posetive lead disconnected. it just doesnt make sense to me.
does he have a cap, cause when i had one it would soemtimes blow the fuse and what amp fuse is he running?
Check ur wire
J
x2....dont risk it if you dont have the time to do the job rite!
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
whenever installing a fuse always disconnect the negative first not positive ........ place the fuse in and then connect the negative and you shouldn't have a problem. i use to blow fuses left and right with unhooking just the positive and not the negative and then i learned to just unhook the negative and leave the positive hooked up. try and see if that works.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 316 Guests (See full list)
