my saturns acting up. low rpm acceleration, miss, stumbles, bogs
Hey guys having issues with my Saturn.
It's a 93 sc2 1.9l Twin cam 5spd
I've had a persistant code 32 with this Saturn and my previous Saturn...ive changed the egr valve and solenoid more than once with both cars and have never been able to get rid of it.
Now I've picked up a code 26... The ses light comes on after the vehicle has been running for about 20 seconds.
My symptoms are hesitation,backfiring through intake, sputtering, missfire ect. Basically it falls flat on its face when I take off and when getting back on the accelerator after shifting. It will fall on its face for a second and then pick back up with no problem. It does burn some oil but nothing like it did with the old motor.
Any ideas?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
I am dealing with the same crazy stuff in my truck. I have changed all kinds of parts and not fixed the problem. My next part test is going to be the Idle Air Controller (IAC). Then a throttle position sensor if the IAC doesn't fix it.
First of all change spark plug and spark plug wires then buy a cleaner for injector that will take care of it
I wish mine was that easy. I have replaced distributer, plugs, coil, spider injectors, wires, egr,fuel pump, fuel filter.
Edited by Smoove
Plugs are new a week ago. Wires are about a year old but are aftermarket...I've got plenty of wires laying around so ill try them. My next plan of action is the tps and map sensors along with the vacuum canister possibly
3 Kinetik Hc2000's
Dual 200amp alts.
Yea, plugs and wires and anything else associated with it.
Also, found this for your code 26
Code 26 (according to Haynes):
> Quad Driver output fault
> Possible cause: The PCM detects an improper voltage level on the circuit that
> is connected to the Quad Driver Module.
> Now, my questions are... What IS the Quad Driver Module, what does it do, and
> where is it?
Pretty vague, isn't it?
First of all, don't panic. Usually, this is not a serious
problem. Let me explain.
Code 26 is a *very common* SES indication to get with a Saturn that
has a few years on it. Most of the solutions, luckily, are not costly.
However, this may depend on the year of your car.
Background
The "Quad Driver" is a device in the computer that "drives" electro-
mechanical devices in the car. Computers run with very little current
(milliamps or microamps) in their circuits. But the devices that
turn on your cooling fan, bulbs, or emissions relays may require
current in a higher range, say tenths of an amp.
Thus, the computer can't talk very well with such a high current
device. It needs help, and it gets in in the form of this Quad Driver
device. The computer sends a signal (very low amps) to the driver, and
it in turn then signals the electromechanical device to do whatever it
needs to do with a higher current which that device can use.
It sort of "drives" the device by remote control.
Code 26
OK, fine, that is the theory. So why the code 26? Well, in almost all
cases, the actual driver device does not fail. What fails is one of
the electro-mechanical devices attached to it. The way the SES light
works, it will come on when either one of the driven devices fails or
if the driver itself fails.
The good news is it is usually not the costly driver device. The bad
news is this is called a "QUAD" driver. That means it drives four
devices. Even worse, there are usually TWO quad drivers, so you have
a total of EIGHT devices to check for just this one SES light.
That's right, code 26 means that one of 8 devices (and a 9th, the driver
itself), could cause the problem. You have to check 8 different things.
Probable causes
I don't have my manual here, but I'll try to remember to post the
exact devices to check. The following is from memory, so bear with me.
Also, remember my car is a '91, so this may have changed somewhat in
following years.
The QD generally drives things like relays, solenoids and light bulbs.
There are a few things that are easy to check, like the bulbs and
relays.
The SES bulb and (I think) "HOT" bulb are driven by this device. You
should check that they both come on when you put the car to "on" before
starting. Of course, the SES must work, since it came on for you.
Then the A/C relay and Cooling fan relay are driven. For A/C, simply
check that your A/C works OK. The relay is pretty silent, unlike
some cars, so you can't always hear it click. Just make sure it works.
The cooling fan can be checked when you sucked out the code. Since you
know how to get the code, you should have noticed that the FAN comes
on for a while before getting the code out. (The bulbs also light.)
If the fan isn't coming on, check the relay. The Haynes manual probably
tells you exactly when the fan comes on during the procedure.
The relay is accessible in the under-hood fuse block.
After that, it gets tougher. You have to check some emissions solenoids.
From what I've read, the MOST COMMON cause of code 26 is either the
EGR solenoid or the canister purge solenoid. The EGR solenoid is
real easy to access. It sits right above the EGR valve and takes a minute
to disconnect on Sx2 models. The canister purge solenoid is a pain.
It is attached to the block on the firewall side. You have to take it
out blindly by putting your hand through a small "hole" between all the
hoses and wires.
I forgot what else is controlled by this device. I'll try to get
my manual tonight to look.
I had an SES light last spring. In my case, I guessed wrong.
I narrowed my SES last year down to the CPS or the EGRS, and incorrectly
deduced the CPS. What a pain to replace this. But I was wrong. That
wasted $20. My problem was the EGRS, and it was also a $20 part. Very
easy to replace.
I should mention that my symptoms were opposite of yours. Mine would
come on only while driving for a while, then go off when I stopped.
I should also mention that the CPS and EGRS are common causes of
code 26, and the irony is they are both Nippondenso parts, made in
Japan. How ironic!
Either way, if you take it for service, the Saturn diagnostic computer
should be able to discern between the two or any other device that
is causing this code. They can read more information than we can
by just pulsing out codes.
So, depending on your skill and your luck, you may or may not want to
try this. Like I said, most of the them are easy, thus even if Saturn
service does it, it usually is not costly.
==== Quote Off ====
And a followup:
==== Quote On ====
This is a follow up to yesterday's post about a "quad driver" fault.
Yesterday I mentioned the causes for a "code 26" fault with the
SES light. There I detailed the following causes:
1) SES light burned out
2) "HOT" light burned out
3) A/C relay
4) Coolant fan relay
5) EGR solenoid
6) Canister purge solenoid
I couldn't remember the other two causes. Remember, the "quad" in
the driver means it controls 4 outputs. Since there are 2 QDMs,
they control 8 outputs.
The other missing items to check are:
7) Speedometer output
8) Upshift/Shift to D2 bulb
10501650_10203332501847103_1859383749711
Blown
Thank you for all of the info sayhuh? It's supposed to warm up a couple days this week so I'm going to have to get my dmm out and start checking these circuits. It's irritating that both codes tell me the same list of crap that could be wrong. I know my vacuum hoses are good since I just replaced them when I changed the motor. I didnt get the code 26 till I hit the.deer a few weeks ago. I think the purge canister is up there somewhere
3 Kinetik Hc2000's
Dual 200amp alts.
  • Who's Online   0 Members, 0 Anonymous, 864 Guests (See full list)
