I have two JL audio w6 12's in a ported box with both subs facing down toward port, when i put my face up to the port i can smell a faint smell from the subs? It does not smell like the memphis that i burned up but it is making me worry!
The JL's should smell like perfume when they get burned up, if not please go back to the dealer.
(it's probably because the subs are still brand new and the glue still has to cure fully )
Its mostly when there hitting below 30hz. they push alotttt of air out and they smell werid lol. just making sure (as the subs are only a week and a half old)
its coil or glue.. either way its time to turn it down when you smell that.
i think if you reach back and put your hand on the cone and its not super hot that its just the glue, but if its pretty hot, then its coil.
dont quote me though
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
They never get warm? i have the headunit at 24/35 and my ipod 80% flat EQ. I dont bass out like most people do. Both of the subs make a scratching noise when i push them past half way. i dont know if that normal? Both subs are very easy to push it also
Maybe you're smelling the inside if your box.
The box does have a leak where air goes through ( to the magent of the subs) since there inverted and the cones shoot down into the port i might be smelling that?
Very easy to push? So they aren't new i suppose?
They are probably pushed to the max by the previous owner and the coil is probably f**ked up and the spiders aren't as effective as new because they are worn out.
  • Who's Online   0 Members, 0 Anonymous, 1194 Guests (See full list)
