would two 8" vvx subs sound good in a fourth order? want to upgrade from the mtx's i have now and wanted to get some 8's to replace them with so opinions welcome
well malibooms 12 vvx did well in a 4th so like said above yes they should do good in one if built right
edit: let me fix this
Edited by Jd1102
how would you built a 4th order "right"?
trial and error or have someone thats knows what they are doing design it and you build it like ramdesigns
makes sense. i've heard that 4th orders are better with a 1:1 ratio, is that true? if so i was tinking of doing it with 3 cubes sealed and 3 cubes ported. and what frequency would i want to port it at so i could hit some pretty low notes?
ok hopfully someone will chim in and hopfully lead me in the right direction. and if not i at least have some one to goto for a box design. and thank you for the help
It all depends on the woofer and car, some subs like closer to a 2:1 for music where as other like closer to a 1:1 generally the smaller sealed to ported ratio also means a betters power handling yet smaller bandwidth...
Generally speaking IMO a 2:1 ratio around 50hz is a good place to start when designing one.. But the best way is to build a number of them and see which one you like the most, as in build a 3:1 a 2:1 and a 1:1 with interchangeable ports and switch tuning freq anywhere from 45-55 hz..
Laying frame soon.. System has to wait
