When people say clamped there amp they mean ac volts timez ac amps. Is that clamped power? I know theother formula where you do box rise im talking just clamped powrr?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
box rise is ac/vc example. 55.3/11.2=4.9 om than minus what ur wired to say 2 ohms and 4.9-2=2.9 box rise than u have 2x box rise or reactive rise. it sound confusing but when person shows u its simple math.
Example: (50AAC x 10VAC = 500 watts) VAC = AC Voltage AAC = AC Amperage
Edited by ShakeNbass
personal best for 2012 new best
148.4 at 50 hrz on 2500 watts clamped with 2 dd3515 on audiobahn a5000spl
133.3 extreme score
2 dd3515 2004 model dual 2s
audiobahn a5000spl amp wired at .5 ohm daily
q power ofc zero gauge wire.
4 batteries in trunk
Ac voltage out of pos speaker and neg speaker and ac amperage around positive I usually burp my system at peak freq...then calculate in 70% efficiency
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
1 Volt meter is placed on the speaker leads coming out of the amplifier.
1 Ammeter/Current meter is “clamped” around the (+)speaker lead coming out of the amplifier going to the subwoofers. Competitors are asked to have these wires accessible. The “peak hold” feature is selected on both meters. During the run, the meters will keep track of the peak voltage, amperage/current going to the subwoofer.
thats how we do in midwest spl
133.3 extreme score
I know how to do it usong box rise but when ppl say they clamped an amp at so and so power dont they just times voltage and amps or do thy actually caluclate it includong box rise?
They usually are too lazy, so they say "I clamped at 1245 watts on a 1500 watt amp wired at .5 ohms, this amp is junk..."
If they new about box rise, and realized that their box sucked, then they'd redo the box.
If you do it yourself, take the extra 2 minutes to calculate and factor in box rise so you know what you're actually working with.
Gimme a minute to grab a link for you, better write-up.
Edited by HatersGonnaHate
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
Double post.
Thank you.
didnt want to start a new thread, i decided to go clamp my amp for shits and giggles, and i got weird as numbers.
ACV = 199.7
ACA = 16.8
Voltage 14.2 dropping 12.6
those numbers look wrong in the first place just due to how high the ACV is and how low the ACA is. also this would imply something like a 2 ohm to 12 ohm rise.
:trippy: :trippy:
