Need more port, Common port should be 3, Try to shrink it down a little too, Somewhere around 4 to 4.5ft would work well.
Edited by CaPRiCEx383
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
needs more port... and whats ur plans for bracing? and the common port walls like said before.. and i would think two would displace more than .09 lol
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
I'd say around 4-4.5 net about 14-17 sq in of port per cube. And those woofers displace more than .09. :)
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Alright just try working on the port keeping the dimensions the same, Try a wider port until you get within the 12-14 range at least. So try like 4.5, then 5 then 5.5 and so on until you get in the range and then adjust length to what u want.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
no 1 AudioQue SD 2.5 woofer has .09 displacement. and 4.cu.ft is to small last time i am going to say AQ Subs like alot of air and perform better on a lot of air.
Did you have the AQ 1200 last time?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
ok, you need to put .18 in the displacement, 3 common port walls, 1 in the extra baffle, and way more port
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
  • Who's Online   1 Member, 0 Anonymous, 543 Guests (See full list)
