If its on the left or right side, It needs to be the same size as the width away. If in the middle, Half of the width going both ways.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
the width of the port..if longer than make a bend
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
AQ 1200.1 D is the ONLY Amp i have ever owned
also i went from 1.5 cu.ft on a single 10" sd 2.5 sub at 35hz to 2.00cu.ft at 35hz and it was way better. completely only thing in the set up that changed was the box not the port placement sub placement or type of port only thing that change was cu.ft
and Ken at AQ , AMICustoms , Dan and few other people recommended 35-38hz an .5 cu.ft more for each sub then a normal 12" cause of the fact that they like more air and they like being tuned in that area. ye si have tested it yes they o like more air.
That looks better, Common port walls should be 3. Is there anyway you can get more port though? If not that will get you by i guess.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
  • Who's Online   0 Members, 0 Anonymous, 925 Guests (See full list)
