Airborne Posted April 7, 2012 Report Posted April 7, 2012 not being a douche..... but weaving a weld is one of the most best ways to get porosity build up in your weld. be careful I agree, the color looks good around the welds but it isn't necessary to go back and forth. A good solid bead is all you need when welding GMAW
uhoh_45 Posted April 7, 2012 Report Posted April 7, 2012 not being a douche..... but weaving a weld is one of the most best ways to get porosity build up in your weld. be careful I agree, the color looks good around the welds but it isn't necessary to go back and forth. A good solid bead is all you need when welding GMAW i disagree about the weaving and porosity... your going to get porosity if you get oxygen/nitrogen in your weld zone and your going to get lack of fusion if you weave and you ride the puddle .... if i was welding up those frame rails i would have done a quick down hand "root" and a vertical "weave"... hell i might even do a "cap" 1/8" on each side of the weld zone... keep the pics coming earth- shits coming along nicely R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
down2earth Posted April 7, 2012 Author Report Posted April 7, 2012 not being a douche..... but weaving a weld is one of the most best ways to get porosity build up in your weld. be careful I agree, the color looks good around the welds but it isn't necessary to go back and forth. A good solid bead is all you need when welding GMAW i disagree about the weaving and porosity... your going to get porosity if you get oxygen/nitrogen in your weld zone and your going to get lack of fusion if you weave and you ride the puddle .... if i was welding up those frame rails i would have done a quick down hand "root" and a vertical "weave"... hell i might even do a "cap" 1/8" on each side of the weld zone... not being a douche..... but weaving a weld is one of the most best ways to get porosity build up in your weld. be careful I agree, the color looks good around the welds but it isn't necessary to go back and forth. A good solid bead is all you need when welding GMAW i disagree about the weaving and porosity... your going to get porosity if you get oxygen/nitrogen in your weld zone and your going to get lack of fusion if you weave and you ride the puddle .... if i was welding up those frame rails i would have done a quick down hand "root" and a vertical "weave"... hell i might even do a "cap" 1/8" on each side of the weld zone... keep the pics coming earth- shits coming along nicely keep the pics coming earth- shits coming along nicely thx man i am not a pro welder by any means i learned all by my self by just picking it up and going to town on scraps of steel im only 22 so i have only been welding for about 2 years on little things so ill take all advice i can get haha now i did do fish plate on the rear of the box tube ran out of 1/8 steel so i have to wait to get some to do the front my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
Cosner90 Posted April 7, 2012 Report Posted April 7, 2012 not being a douche..... but weaving a weld is one of the most best ways to get porosity build up in your weld. be careful I agree, the color looks good around the welds but it isn't necessary to go back and forth. A good solid bead is all you need when welding GMAW i disagree about the weaving and porosity... your going to get porosity if you get oxygen/nitrogen in your weld zone and your going to get lack of fusion if you weave and you ride the puddle .... if i was welding up those frame rails i would have done a quick down hand "root" and a vertical "weave"... hell i might even do a "cap" 1/8" on each side of the weld zone... keep the pics coming earth- shits coming along nicely well sir. apparently you have not done alot of welding were they xray it? weaving=fail. i have my welds xrayed daily. i've been welding for 11 years. professionally for 6. and you wouldve vertical downed a weld? What the fuck?!? NO!! if you want a syrong structural weld you do a quick hotpass aka"root" the stringer fillers. no cap needed. for structural. now let us see pictires of your welds mr theory.
Airborne Posted April 7, 2012 Report Posted April 7, 2012 not being a douche..... but weaving a weld is one of the most best ways to get porosity build up in your weld. be careful I agree, the color looks good around the welds but it isn't necessary to go back and forth. A good solid bead is all you need when welding GMAW i disagree about the weaving and porosity... your going to get porosity if you get oxygen/nitrogen in your weld zone and your going to get lack of fusion if you weave and you ride the puddle .... if i was welding up those frame rails i would have done a quick down hand "root" and a vertical "weave"... hell i might even do a "cap" 1/8" on each side of the weld zone... not being a douche..... but weaving a weld is one of the most best ways to get porosity build up in your weld. be careful I agree, the color looks good around the welds but it isn't necessary to go back and forth. A good solid bead is all you need when welding GMAW i disagree about the weaving and porosity... your going to get porosity if you get oxygen/nitrogen in your weld zone and your going to get lack of fusion if you weave and you ride the puddle .... if i was welding up those frame rails i would have done a quick down hand "root" and a vertical "weave"... hell i might even do a "cap" 1/8" on each side of the weld zone... keep the pics coming earth- shits coming along nicely keep the pics coming earth- shits coming along nicely thx man i am not a pro welder by any means i learned all by my self by just picking it up and going to town on scraps of steel im only 22 so i have only been welding for about 2 years on little things so ill take all advice i can get haha now i did do fish plate on the rear of the box tube ran out of 1/8 steel so i have to wait to get some to do the front you are doing pretty damn good though! It's just that "weaving" or "C pattern" type welding is (from what I remember in metals 15+ years ago) used when welding up hill inside a corner or something like that. In your application a good controlled bead is all you need. Weaving reheats the filler you just laid and can make it brittle of become porous
uhoh_45 Posted April 7, 2012 Report Posted April 7, 2012 well sir. apparently you have not done alot of welding were they xray it? weaving=fail. i have my welds xrayed daily. i've been welding for 11 years. professionally for 6. and you wouldve vertical downed a weld? What the fuck?!? NO!! if you want a syrong structural weld you do a quick hotpass aka"root" the stringer fillers. no cap needed. for structural. now let us see pictires of your welds mr theory. you are correct i dont have my welds xrayed daily and i dont do structural but i do have my CWB all position with mig (structural all positions with Gmaw)... i do pipeline welding in shop (random xrays- never failed) where it is vertical down root- hot pass/fill pass vertical up heres procedure for a 3G which is a vertical grove weld ... which is exactly what down2earth is doing heres my root 1/8" gap vertical down then heres my hot/fill and cap vertical weave up and the bend test (30 ton ram) no lack fusion no porosity no cracks only problem is there was little suck back from to much heat on front side and sorry OP for thread jacking R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
down2earth Posted April 7, 2012 Author Report Posted April 7, 2012 hey man don't be sorry Ill take all the help I can get man my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
Hollowstylez Posted April 9, 2012 Report Posted April 9, 2012 Love the metal fab going on here, keep taking those pictures buddy.
down2earth Posted April 9, 2012 Author Report Posted April 9, 2012 Love the metal fab going on here, keep taking those pictures buddy. thanks man my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
