How To Do The Big 3: Tutorial
Guest MegaloManiac
Guest MegaloManiac
yeah that would work to but I wanted to save wire since my alt is on opposite of battery.
  • 4 weeks later...
i am going to use 4 gage wire is that safe and what size fuse should i use?
Totally depends on what kind and how much equipment you wanna run.
List the components in your system and any mods/upgrades you have done thus far.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
i am running a pioneer 5900 ib cd player, a mtx ta 7801 amp, a kinetik power cell hc600, 2 alpine type r 15s (new model) in a box built to their specs they hit hard but i have a little dimming. im going to eventually put a bigger alternator but someone said that the big 3 would help.
Well who ever told you THAT.....was correct.
It will help to minimize the dimming assuming your electrical is enough for what ur running to begin with.
From the info given-doing the big 3 with 4ga would be an improvement over NOT doing it obviously and it would help, and it would EVEN prolly be sufficient for what your running right now....but it's kinda the sort of thing you'd really only wanna do once to save oyurself having to undo the work of running the 4ga wires just to have to replace them with BIGGER cables later when you upgrade-which it sounds like you plan on doing.
They call it the BIG 3 because generally you wanna use the biggest cable possible for max flow of electrical current.
I'd say consider what upgrades you plan on doing in the future-if you can see yourself with amps totalling MORE THAN 1200rms, you should do the big 3 with 1/0ga cables and the fusing will depend on how much power you are trying to pull thru each cable.
Look at the fuses IN your amp or check it's owners manual for the MAX power consumption in AMPERES/amps and make sure you fuse equal to or just above THAT total...i.e. if you have 80amps used by your amplifiers, use an 80-100amp fuse.
The other theory is to fuse according to your alternator output on the cable comong from the alt + post.
Just go as high or a bit higher than your alternator is rated (in amperes) so you are not limiting it in any but will be protected from short circuits.
i have a total of 80 amps in my amp and i think my alternator is only 130 amps. so would it be smart to run 100 amp fuse and use either 1/0ga? and one other question the hot wire from the alternator (in the big 3) i run that to my pos. side on my battery right? ill probably just add another amp but im not looking to go all out like some of the people on here. its nice ! i just dont have the money. i have already been raped for $3,000 for what i have so far. but thats what happens when you dont want to wait.
Could I use a 150 amp fuse holder as opposed to a 300 amp fuse holder? And what if you don't have those special battery terminals? Can you just use more ring terminals?
2008 Chevy Impala (undercover cop style)
Setup in the makings
yes you can. and a 150 amp fuse holder is the same as a 300. just gotta change out the fuse ;)
So basically, I don't have to use battery terminals, I can just use ring terminals instead? That means I don't have to cut wires right off my battery like I would have to with battery terminals.
  • Who's Online   0 Members, 0 Anonymous, 1278 Guests (See full list)
