Enough electrical?
So I'll be running a bc3500 at .67 to begin with. I wanted to double check and make sure my calcs are close to what my needs will be.
For the time being with one amp I plan on running 2 stock Alts, around 60 amps at idle each, 4 agm batts with 65ah and 4 runs of pos and 4 neg of 1/0 from front to rear bank. I think that should suffice for the single amp..
Then as funds come in I will be grabbing 2 singer 350a Alts 200 idle and maybe two more matching battery's to go along with another 3500 after the electrical is up to par to run both.. Same runs front to back then more runs from back bank to amps..
Both setups will have a mla module for 15.4 charging daily.. So one amp should pull around 350-380 amps and according to my fist calcs 60a per alt is 120 plus 65ah per battery is 260 and 260 plus 120 = 380.. Minus 40a to run vehicle which leaves ~340a which is just a tad lower than demands.. Is it safe or should I get a 5th or 6th battery before I run the first amp
Laying frame soon.. System has to wait
You will be fine, I am running my truck right now off 1 160 amp alt and 5 batcap 4000s, but I am running 2 3500d.1s, I have drop but I don't full tilt it for long I am waiting on new alts. But you will have some drop but not much. Just remember this if your alts amp output doesn't match what you amp is pulling you will have voltage drop. So if you have 120 amps worth of alt then you can only run around 1500 watts without drop. Granted that is at idle so I would suggest reving to help maintain voltage.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Well I thought about it and i can do 2 batts equivalent to the deka intimidator grp31 100ah to go with the two under hood "78" series and add two more 31s soon there after just to run the one 3500.. When I can afford the new
Alts I'll think about adding a second amp.. Till then it's Savin for batters
Thank you
You should be fine with those batts with one 3500.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
We shall see, my plan is for a nice daily setup, with alot of demo time.. So hopefully everything goes as planned..
Quick question tho, an mla module, if i purchased one would the same one work with the stock Alts and the singer 350a ones? Or would that require a new one
If it is 4 pin plug it will work with either of them.
Evo X build log
That's what I thought, sometimes I like to bounce my ideas on others as a way of catching something I may have missed. My build should resume in the coming weeks.
Thanks for your help :)
  • Who's Online   0 Members, 0 Anonymous, 2010 Guests (See full list)
