You seem to not know very much about the whole situation. You go balls to the wall with equipment but not know anything about charging voltages or batteries or alternators? Not trying to sound like a ass but just putting that out there.
And this is like your 4th thread about this? It's been answered probably dozens of times?
What happened to the XS power battery you had?
Edited by Rebel4055
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
Well at 1 ohm that AQ pulls 380 amps, .5 I'd say you're pulling close to 500 amps. Get another battery in the back and replace those optimas with some good sealed agm batts. Then just keep an eye on your voltage.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
i never ran an aq at.5 ohm before and i never had an alternator with this much amperage and charges at 14.8 volts ,i just dont wanna blow the amp so im being carefull thanks for the help u guys giving i really appreciate it i plan on running 2 aq 3500.1 but as i said for couple of weeks i wanna run the one that i got at .5 ohm just being carefull people thanks keep the information coming
Just dont let your amp drop below 12.5 especially at .5 ohm. Lower resistance equals more heat which equals more stress on the amp. You'll need a couple more batteries if you wanna run 2 aq's
under construction
u hate c-fizzy?
yes i plan on running 2 100 ah batteries per amp when i get the next aq plus another 2 batteries for mids and highs. the reason i asked about the 14.8 voltage alternator is because my car is a 94 toyota corolla and i really dont want to burn up my brain box or other stuff
Lowest working voltage is 9.5 then it will protect or blow. Lowest I would go is 10.5 on a burp, on daily I would try to stay above 12.0, but with the electrical you mentioned it should stay at or above 12.9-13.0 volts no problem. And that amp can safely run daily as high as 16.8, your batts at safe up to 15.0 so everything looks great. And YES I have daily this amp at .5 ohm and lower, actually down to .25 ohm.
Even the AQ demo scion with the two hdc4 12s, off one aq3500d.1, they run it at .25 ohm daily.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
