I have 8 gauge wire running from a previous amp I just uninstalled. I bought a renegade 850 s and it says that 4 gauge wire is required. I checked and the 8 gauge will fit as long as I tighten down the screws enough on my am, but me question is: can I use the 8 gauge wiring I already have installed safely? Or am I s.o.l. and need to run all new wire?
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
of course smaller wire will fit into a larger wire hole! duh. can the 8 gauge supply the current for 850 rms. no. that is why they said 4 guage is required. use 4 gauge or larger. otherwise ur amps gunna work hard and get hot, your 8 gauge wire will get hot creating a fire hazard. use 4 gauge
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
The thing is its only pushing 400 watts rms. That's why I thought it might be okay to use the 8 gauge.
Subs/Amps: TBD
well for 400rms you should technically be ok running 8 gauge. YEa what is fuse rating? the thing is if it is trying to suck power, a smaller wire will put more strain on amp. especially for low frequenzy power hungry notes
BMW M340 xDrive
it comes with a 30 amp fuse, was thinking about upgrading it to a 40 though.
Subs/Amps: TBD
you can go up to a 50 amp fuse max on 8 awg.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
My bad I just looked to make sure, the amp rating is 25amps x 2
Subs/Amps: TBD
if the amp comes wuth a 30a fuse DO NOT put a bigger one, there is a reason to why it has a 30a fuse, running a bigger fuse will hurt more than to help making your amp burn down even before the fuse blows
the hellllll :No: :No: :No:
keep the 30 in there, switching around fuses like that will most likly cause your amp to go up in smoke, and put more strain on your power wire itself, just switch out to 4gauge and make your life easier
fucking ninjaed by miguels -.- but still my post applies
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
