jekeke Posted February 1, 2012 Report Posted February 1, 2012 I've designed and enclosure for the two 12" lethal injections I'm buying. Enclosure style: Vented L Enclosure: 14" Height, 36" Width, 30" Depth .75 MDF Volume Displacement in cubic ft: Woofers: .22 Braces: .21 Netl Volume: 7.11 Gross Volume without port: 6.68 Port Specifications: Port Diameter- 11 Port Total Length- 36" Lv Port Width- 4" Port Height- 12.5" First part of port- 28" Second part of port after bend- 6" Tuned 32Hz Port Area- 95" squared Port Volume- ?? Someone help please? I just need to know the port volume so I can figure out gross enclosure size. Also do you think this enclosure will work well with the 2, 12 inches subwoofers. Thanks
Joe X Posted February 1, 2012 Report Posted February 1, 2012 The IA 12"s are specified for 1.75-2.5 cuft each, Here is a design suggestion where I picked about 2.25 cuft per driver at about 33Hz tuning and on your dimensions: Enclosure Specifications: Fb = 32,62 Hz Vb = 4,504 ft^3 Subwoofer Mounting = Flush Mounted External Height = 14 in External Width = 36 in External Depth = 27 in Port Width = 6 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 36 x 14 Left & Right Sides = 24 3/4 x 12 1/2 Top & Bottom = 36 x 24 3/4 L Port Internal Assembly Parts: Front to Back = 18 3/4 x 12 1/2 Extension = 5 x 12 1/2 Let me know what you think.
jekeke Posted February 1, 2012 Author Report Posted February 1, 2012 System Build: 2x Incriminator Audio Lethal Injection 12 Inch Woofers Daul 2 Ohm Voice Coils 1x JL Audio 1000/1v2 Slasher Amplifier 1200HC Kinetik Battery Stock Battery 0 Gauge "The Big Three" Capacator 1 Farad Enclosure Specifications: 3/4" MDF Material Height: 14" Width: 36" Depth: 27" Gross Volume: 6.364 Volume Displacement: Port - 1.04 Cubic Ft Flush Mount Baffle - 0.08 Cubic Ft Woofers - 0.22 Cubic Ft Bracing - 0.056 Cubic Ft Total = 1.40 Cubic Ft Net Volume: 4.96 Cubic Ft Individual Woofer Volume: 2.5 Cubic Ft Subwoofers Facing Upwards Port Specifications: Port Area: 76.50 Height: 25.5" Width: 3" Length: 26" Tuning Freq: 32.60 Hz Volume 1.04 Cubic Ft Ports Facing Upwards Is this going to work good?
Joe X Posted February 2, 2012 Report Posted February 2, 2012 The equipment will work, the enclosure numbers don't match. If you want to come up with your own numbers get the Torres calculator. As far as I am concerned the suggestion I gave you would work best, even if you add the 45s the net volume won't change enough to have an effect.
jekeke Posted February 2, 2012 Author Report Posted February 2, 2012 The equipment will work, the enclosure numbers don't match. If you want to come up with your own numbers get the Torres calculator. As far as I am concerned the suggestion I gave you would work best, even if you add the 45s the net volume won't change enough to have an effect. According to Nick at incriminator audio the tech support/owner I believe said to go with a 2 1/2 cubic ft per subwoofer more then the box you designed. This box is 2 1/2 per woofer, with 75 squared inches of port. He said to go 70 for 6 cubic ft box and this is 6.3 so i bumped it up to 75. Let me know what you're thinking. He also said to tune it to 35 but I think I'll like 31-33 better.
Sergeant_Skyrim Posted February 2, 2012 Report Posted February 2, 2012 The equipment will work, the enclosure numbers don't match. If you want to come up with your own numbers get the Torres calculator. As far as I am concerned the suggestion I gave you would work best, even if you add the 45s the net volume won't change enough to have an effect. According to Nick at incriminator audio the tech support/owner I believe said to go with a 2 1/2 cubic ft per subwoofer more then the box you designed. This box is 2 1/2 per woofer, with 75 squared inches of port. He said to go 70 for 6 cubic ft box and this is 6.3 so i bumped it up to 75. Let me know what you're thinking. He also said to tune it to 35 but I think I'll like 31-33 better. He might've said that it'll be around 6 cubic feet total gross volume (including port/woofer displacement) which would give around 4.5 cu ft for both woofers Build in progress
Joe X Posted February 2, 2012 Report Posted February 2, 2012 Ok here is what you seem to want Enclosure Specifications: Fb = 32,9 Hz Vb = 5,038 ft^3 Subwoofer Mounting = Flush Mounted External Height = 14 in External Width = 36 in External Depth = 30 in Port Width = 7 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 36 x 14 Left & Right Sides = 27 3/4 x 12 1/2 Top & Bottom = 36 x 27 3/4 L Port Internal Assembly Parts: Front to Back = 20 3/4 x 12 1/2 Extension = 2 x 12 1/2 Let me know what you think. The reason I went below the limit of Vb is because that's what you usually do when you are intending to run subs above their rated power to avoid overexcursion damage.
