AMI CUSTOMS Posted February 2, 2012 Report Share Posted February 2, 2012 I'd bet the amp goes first On a D9? That amp will run for DAYS at .5 ohm. And to the OP, yes they will handle that power. have you ran a d9 at .5 for daily ripping on it full tilt? Me personally, no, I do just so happen to have an RD D9 now for another project, but I know several people who have them, and I have setup oscoped this amp on a few different competitors vehicles so I know what it can and can't do. Also doesn't hurt I am good friends with the current owners. i was just asking, i have seen them in the lanes be EXTREMELY successful at .5, sometimes lower, but all were burps. not daily. OP it's all about application. I have a teammate that ran his daily at .5 ohm for months in a trunk car on two warden 12s, doing 150s. He blew his actually because it was in trunk on a 115 degree day and dropped voltage down to about 10 volts, smoked it. But no doubt would have been fine if voltage was up and didn't have the heat in a trunk. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty Link to comment Share on other sites More sharing options...
CJSmith Posted February 2, 2012 Author Report Share Posted February 2, 2012 My D9 is in well ventilated area, and never sees under 14v. and 50% of the time, I'm doing burps between 40-55hz.... I just wasn't sure if those subs could take that much power. I know they're very high quality, but I've never personally ran them until now and was just trying to get some opinions. *Rebuid in progress* Link to comment Share on other sites More sharing options...
CJSmith Posted February 2, 2012 Author Report Share Posted February 2, 2012 depends on what exactly you mean by amp at full tilt... I mean, having the amp turned up to get the most power out of it, without having a clipped signal. *Rebuid in progress* Link to comment Share on other sites More sharing options...
AA98hoe Posted February 2, 2012 Report Share Posted February 2, 2012 I'm pushing 4400 watts to each of my mayhems daily yes they can handle it and want more...:-) TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
AA98hoe Posted February 2, 2012 Report Share Posted February 2, 2012 Double post fail...anyways don't clip the amp trying to get the most power out of amp...keep your voltage up...an u will be fine TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
CJSmith Posted February 2, 2012 Author Report Share Posted February 2, 2012 Double post fail...anyways don't clip the amp trying to get the most power out of amp...keep your voltage up...an u will be fine [/quo My amp is about 75% of the way up, so they're getting about 2700 RMS each, so I should be good then. lol.. Thanks for the help. *Rebuid in progress* Link to comment Share on other sites More sharing options...
MrSkippyJ Posted February 2, 2012 Report Share Posted February 2, 2012 Double post fail...anyways don't clip the amp trying to get the most power out of amp...keep your voltage up...an u will be fine My amp is about 75% of the way up, so they're getting about 2700 RMS each, so I should be good then. lol.. Thanks for the help. I would up my signal input voltage if you are going to be running the amp at .5 ohm. so you don't have to run your amp at 75% gain. Just me though, I like being able to keep my gain as low as possible. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
TRTC360 Posted February 2, 2012 Report Share Posted February 2, 2012 Double post fail...anyways don't clip the amp trying to get the most power out of amp...keep your voltage up...an u will be fine My amp is about 75% of the way up, so they're getting about 2700 RMS each, so I should be good then. lol.. Thanks for the help. I would up my signal input voltage if you are going to be running the amp at .5 ohm. so you don't have to run your amp at 75% gain. Just me though, I like being able to keep my gain as low as possible. I'd do the same but not through a line driver, if your headunit has 2v preouts try getting a headunit with 4 or 5v preouts, I'm not sure about this amp but most amps don't like being line driven. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360 Link to comment Share on other sites More sharing options...
CJSmith Posted February 2, 2012 Author Report Share Posted February 2, 2012 Double post fail...anyways don't clip the amp trying to get the most power out of amp...keep your voltage up...an u will be fine My amp is about 75% of the way up, so they're getting about 2700 RMS each, so I should be good then. lol.. Thanks for the help. I would up my signal input voltage if you are going to be running the amp at .5 ohm. so you don't have to run your amp at 75% gain. Just me though, I like being able to keep my gain as low as possible. Are you talking about running higher voltage to it, so it can put out the same power without having the gain as high? *Rebuid in progress* Link to comment Share on other sites More sharing options...
MrSkippyJ Posted February 2, 2012 Report Share Posted February 2, 2012 yeah. not really a factor if you are just burping though. not even sure why i mentioned it to be honest. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
