i was thinking of running 4 SA 8v2 on 2000w rms, i know that part is fine. where i have a question is on the box. i have a 2006 mitsubishi galant and the rear seat does not fold down. there is a hole in the center for the arm rest, and i was thinking of running my port through there into the cabin. either that or porting out the rear deck. which would be a better option?
i see alot of people do it throw the hole in the seat but some prefer it in the rear deck i would assume the rear deck would shake more but not to sure
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
I would assume porting through the deck would sound a bit better, but I would be interested in seeing a port firing through the space in the seats.
it seems less destructive to me to do it that way. make a snug fit beveled port that is even with the rear seat, or slightly recessed.
Hmm, my guess, 4th order through the back seat or 6th order through the deck.
Both would work, probably neither would be much better than the other, so do which ever you would prefer.
If you do the 4th order through the back seat make sure your magnets are in the ported section so you can make sure you can smell coil if your subs are getting hot. Not saying the 8's can't take the power, but since it is a little higher than RMS it would make for a good safety precaution.
Edited by BobbyG2
*New vehicle and system coming soon.*
  • Who's Online   0 Members, 0 Anonymous, 1536 Guests (See full list)
