Box help
RExEAGLE
Im having trouble configuring box specs for 2RE SE-X15d4 both subs will run on 1000 watts in a ported box I'm just having trouble with the specs if anyone has box design tips or specs they would be appreciated
vehicle, goals, dimensions, (dont think i missed anything) someone can help you with a box :)
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
X2^^^ box specs should be figured will all of the above. Also need to know what type of music you listen to, to determine whereby frequency for tuning would best suit you :)
what about POWAH!!!
what amp are you running?
i'd be glad to help out here.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
what about POWAH!!!
re XTX 3000.1 heres the linkAMP
Hip hop so about 36-38 hz ported
You STILL didn't provide any vehicle information, or maximum dimensions of the box. The vehicle is VERY important to give you a proper box idea or design. ALSO, 36-38 is a hair on the high side if you're gonna wanna murder the lows. I'd go 32-35 Hz if it were me. I like the lows to really get down though.
  • Who's Online   1 Member, 0 Anonymous, 1069 Guests (See full list)
