Can someone fix port?
Stee-Z
Here are my current dimensions
Outer dim.
16" high
28" wide
30" deep
Port
2.5" high
26.5" wide
26" long
Net vol. 4.13 ft.^3
tuning freq. 36.33hz
Port area per ft. 16.03 in sq
I have most of the box complete except the port, this is where I want it to be correct. I've had some people tell me that with this current dimensions of the port il have port noise and I should have a little more port area..bla bla bla.
So can someone please fix this to bring this box to its full potential. As you may know im looking for a nice punch in my setup now, since my last box was at 30hz, so I wanted to try around 36-37hz ish area. Thank You
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
that port area should be ok..touch more couldnt hurt but i wouldnt split hairs over it..what theyre referring to is the ratio of ur length to height.. most say a 9:1 ratio... basically your ports to long and skinny and needs to be shorter and fatter lol
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Haha ok thanks, yeh i never understood why it was wrong. never knew that they went by a 9:1 ratio, I guess you learn something new every day. Thanks
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
just something ive heard a few people say.. (reputable people) ive also had better luck with a squarer port
power: dd m4
What sub?
a 9515 DD sorry. im running it with a AQ 2200 also
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
Ok so the width of the box is 28 and the width of the port is 26.5 which means it goes all across the with of the box so one thing that can be done is make it taller and shorter so that is not as thin, Here is a suggetion for the new port:
INTERNAL DIMENSIONS!!!
H = 3.5 in.
W = 22 in.
L = 24 in.
That would leave you at Port Area/Vb = 16.486, port L/H ratio = 6.286, Fb = 36.6Hz
I would also add an extra layer of MDF to the baffle for a flush mount, it would be 16.75 tall then, if you can do it go ahead.
  • Who's Online   0 Members, 0 Anonymous, 422 Guests (See full list)
