i got a dc level 4 18 and last night sub started sound real scratchy and bad for a second then it quit. took it out of the box and found at 1 tinsel lead on each side broke. i wanted to know is it possible to replace the leads so i don't have to spend a bunch on a recone. thanks
I have before but it was a little bit crappy of a fix. Different subs also. I used some 450lbs test picture hang wire and soldered that to the original tinsel lead and then to the terminal. Had the same problem and same fix for 3 of the same woofers. After many different materials tried the picture hang wire was the best in my case anyways. GL
Edited by rogue
thats some ghetto rigging right there...your safest and most reliable is going to be a recone, what kind of power were you running to it? m1's? or m2's? also box specs? how old is it?
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
It worked though. It wasnt pretty and I wouldnt do it on any equipment I have now but sometimes the tinsel leads are not engineered very well and a recone will likely just delay this from happening again.
Are the breaks possibly from bottoming the sub out? Or from normal use?
im gunna take a wile guess and say sub abuse, either over powering(if they burnt up) or over excursion/botteming it out
Clippity Clip Clip, Clippity Clip Clip. That is all......
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
which goes along with my burnt theroy <_<
its a d2 in a 6 cu ft box tuned to 32. no it was not abuse it was set with oscope at volume 23 i never turn it higher then 21, all music i play is decaf or stuff i went through to make sure its not clipping. its on an audiopipe 1500d dosent get hot or smell. the sub is about 2 years old now. it appears that it was hitting the pads on the cone and frayed the wire tell it was thin enough to burn up.
odd that they both went out at same time
that is all heat, user error all the way. when the tinsel is copper/burned color you did something wrong.
Edited by ChevyBoy95
