I need some help designing a box for my truck and I will pay for a nice design.
I need to get this.
The space available is 39 inch Wide, 19 Inch Deep, 35 inch tall
Solo X 18
Into this.
2000 Ford Ranger
Edited by FordRanger
2000 Ford Ranger XLT Ext Cab
Pioneer AVH-P23000
Kicker 6x8s
(2)Kicker CVX 15's
(1) RE Audio XT4000DE V3 MonoBlock Amp
Kicker 1/0 Gauge Wiring Kit
Need more info,
what power are you feeding it?
what type of sound are you looking for ?
are you trying to compete?
what tuning ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Need more info,
what tuning ?
I'll be giving it about 1600 Watts RMS for the time being, not trying to compete just want some loud booms, and around 35-40 Hz.
Pioneer AVH-P23000
Kicker 6x8s
(2)Kicker CVX 15's
Ok so, here is a design suggestion based closely on Kicker's spec for this subwoofer: 10cuft@35Hz port up sub up configuration will work well and is very easy to build:
DIMENSIONS ARE SPECIFIED AS SEEN FROM THE TOP!!
Enclosure Specifications:
Fb = 35,00 Hz
Vb = 10 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 19 in
External Width = 39 in
External Depth = 32,75 in
Port Width = 8 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 39 x 19
Left & Right Sides = 30 1/2 x 17 1/2
Top & Bottom = 39 x 30 1/2
L Port Internal Assembly Parts:
Front to Back = 15 1/2 x 17 1/2
Bracing displacement considered are two wood rods 2 inch diameter 17 1/2 tall for front to back bracing. Also double baffle has been considered. Driver displacement as specified by Kicker is = 239.8 cubic inches. Let me know if you need to see an assembly guide.
Edit: Just a quick idea of how things go:
Edited by Joe X
Fb = 35,00 Hz
Vb = 10 ft^3
Port Width = 8 in
Cut List:
I wouldn't mind a assembly guide! I'm really new to box building!
Thanks man!
Pioneer AVH-P23000
Kicker 6x8s
(2)Kicker CVX 15's
Fb = 35,00 Hz
Vb = 10 ft^3
Port Width = 8 in
Cut List:
Thanks man!
Updated my original post with the assembly guide, let me know any questions.
  • Who's Online   0 Members, 0 Anonymous, 1101 Guests (See full list)
