I am looking into a small DIY ht project. I am leaning toward using one or multiple tc sounds epic 12"(s) drivers.
I can't say I ever saw someone use a 4th order for home theater use, are they ever used?
Here are the t/s parameters:
• Power handling: 500 watts RMS/ 2,000 watts peak
• Le: 3.2 mH
• Impedance: 2 ohms per coil x 2
• Re: 3.66 ohms
• Frequency range: 15 - 150 Hz
• Fs: 24.0 Hz
• SPL: 86.6 dB
• Vas: 3.22 cu. ft.
• Qms: 7.80
• Qes: 0.42
• Qts: 0.39
• Xmax: 22.9
Would this driver be appropriate in a 4th order application?
Just trying to get a few ideas! Thanks SMD
Edited by SPLadd1ct
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
should be a good match. Either that, or those subs would work awesome in a t-line
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
