Can someone please explain this to me?
I'm trying to find out exactly what I need to do in order to run a 2nd battery, I'm 16 and just starting out and trying to learn how to do these things. Right now I've got 4 American Bass 400w max 10's on a 1500w spl amp and I'm noticing headlight dimming and pretty soon I'm planning on doing a build so help would be greatly appreciated.
The most basic would be to put a battery in the trunk (or whatever) and hook the two in parrallel. If you havn't upgraded your orginal battery yet then do that, The two batteries should be close to same age and size and defiantly same brand. You will want to start looking at an HO alternator after that.
Yep, a lot of people will recommend running 1/0 awg from both the positive and the negative of the batteries. This is what I would do, but I have seen people just ground it in the trunk and works okay.
Edit: Don't forget to fuse your positive battery run.
Edited by c.director
Let's start with the basics...have you done the big 3 yet? How old is the battery under your hood? If you haven't done the Big 3 yet, I would seriously recommend it. I did it on all my family vehicles just because..they don't necessarily have high powered car audio, but it improves the charging system, even stock. My dad's 98 Subaru Outback with just a 0 gauge run from battery negative to the strut tower, and the battery positive to the alternator, his charging voltage jumped .4v over factory wiring.
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
Ideally:
Big 3 done in 0 gauge
+ run from + on underhood battery to + on second battery (fuse the run coming off the underhood battery as close to the terminal as you can, and also fuse it where it goes into the rear battery)
- run from the underhood battery to the rear battery (this might be optional depending on your vehicle. It depends on the ground location)
- run from the rear battery to ground.
Edited by SnowDrifter
And the big 3 is a - from the battery to the chassis, and a - to the alt and the a + to the alt?
No. + from alt to battery
- from battery to chassis
- from battery to engine block
2010 Altima Coupe
Kenwood DNX9990HD
JL C5 components
Rockford T1692's
JL HD600/4
JL HD 750/1
JL 12W7AE 2.5 cubes @ 33hz
  • Who's Online   1 Member, 0 Anonymous, 1852 Guests (See full list)
