what parts are needed for a 2000 jeep cherokee v8 engine swap?
ive always had this little dream of putting a 350 or a 383 stroker into my 2000 jeep cherokee, i have a few questions though.
how would i retain use of my speedo and fuel gauge in the dash,
how would you tie into the factory electrical while bypassing the computer
lastly are there any parta i am missing in my list below
.chevy 350 / 383 v8
. turbo 350 transmission
. larger radiator
. new engine mounts
. higher flow rate fuel pump, pressure regulator
. new transmission cross member
. stiffer front springs
. possibly a beefier rear end ( not sure if i have the dana 35 or not)
. ignition module
. serpentine belt accessory drive kit
350 from what? and it can be done but not going to be easy or cheap. and if your really serious/dedicated enough i guess lol your best bet is getting an lt1 or ls1 bolted up to a 700r because for it to be legal the engine being swapped in from a vehicle of the same year of the recieving vehicle or newer. on top of that it MUST be smog passable and obd2 compliant. not going to happen with a say gen1 350 on a turbo 350. only way really to go about it is a ls or lt on a painless custom harness.
also why stiffer springs???
-Zach- '88 K5
- '01 cbr929rr
stiffer springs because i,m sure the 350/383 would weigh down the front end more than the i6 does currently.
as for the legality thing i did not know that, i was actually looking at getting an older 350 and rebuilding it since there are so many of them and there are alot of aftermarket parts, another reason would be because the older 350's are carbed instead of fuel injected
are those regulations about smog and obd2 for every state or is a it a state to state basis?
If you gotta ask don't do it. My .02 cents.
Does your town do vehicle inspections? If so, you're shit outta luck. obd2 ftl
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
yeah they do do the inspections but the emissions arent required
Still.
Inspection checks for misfires and what-not. When they plug their little reader in, and it sees no ecu. You fail inspection.
NVX LOC
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
not here, all they do is check things like the lights,horn,mirrors, and other things like that, they dont check the computer or anything like that
  • 4 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1615 Guests (See full list)
