Box help with level 2 12
sprkn_ranger
Well I just ordered a dc lvl 2 12 and am having a hard time figuring out Torres calc to get the numbers for a box. I really don't need a design, cause I can figure that out, I'm just having a hard time getting to the right box volume and port size. I'd like to have it tuned to around 35Hz, and I'm going to be putting around 600-700 watts to it.
I have plenty of room to work with in my trunk (2007 Kia optima) for a single 12 and plan on sub back, port back. So what cubic foot after displacements should I shoot for and port size? Thanks!
They are specified at 1.25 cubic feet per sub for ported usage and have a driver displacement of .14 cubic feet each. If can tell ehat are your maximum dims I could give you some suggestions.
Well I have a lot of room to play with, my trunk is pretty damn big, not sure on max dimensions. If I say 14" tall and up to 24 inches wide and however deep it needs to be. Oh and I'm going to kerf flare the port. Thanks man!
Ok so I provide the following design as a reference from which you can experiment with the Torres, the kerfing may take some space which you can add as bracing.
Enclosure Specifications:
Fb = 35.062 Hz
Vb = 1.2 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 14.75 in
External Width = 26.25 in
External Depth = 12 in
Port Width = 1 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 24 x 13 1/4
Front Internal = 22 1/2 x 13 1/4
Back = 26 1/4 x 13 1/4
Left & Right Sides:
Side 1 = 10 1/2 x 13 1/4
Side 2 = 11 1/4 x 13 1/4
Top & Bottom = 26 1/4 x 12
L Port Internal Assembly Parts:
Front to Back = 9 x 13 1/4
Extension = 19 7/8 x 13 1/4
This is how it looks and assembles:
Fb = 35.062 Hz
Vb = 2.52 ft^3
External Height = 14.5 in
External Width = 27.75 in
External Depth = 20 in
Port Width = 3 in
Cut List:
Front = 24 x 13
Back = 27 3/4 x 13
Left & Right Sides:
Side 1 = 18 1/2 x 13
Side 2 = 19 1/4 x 13
Top & Bottom = 27 3/4 x 20
Front to Back = 15 1/2 x 13
Extension = 7 1/4 x 13
I really appreciate the help man! But I only have one level 2 12". Not 2. I assume I could just take the box volume and the ports square area in half and it would be the same?
  • Who's Online   0 Members, 0 Anonymous, 904 Guests (See full list)
