I have two preouts on my headunit but I need to install a third amp, The third amp I want to install is a mono amplifier to power the mid-bass drivers in my doors, only bass. Not the full range speakers. could I use the output off of the amp powering my subs? Help please. Never put over 2 amps in my car before so this is new to me.
not to b rude but.. duhh... :D
Blowthrough
Subs
rebuild
Amps
1-SAZ3500
1-T4004
Coaxial
1Set Alpine Type-R Components
1 Set- kicker ks 5.2
1 Set- Kicker ks 6x8
Reciever
Pioneer DEH-P7400HD
2000 Ford F-150 EXT Cab
Clarion EQ
i would use the pass thru on your mid & high amp. last i checked your mid bass didn't drop off at 80-100 hz. use the full range out of the mid & high amp you currently have and cross it over properly. if you wanted a sub up front then you could use teh sub amp as a pass thru.
NEUMAN
How would I want to run the rcas through the crossover? My headunits preouts have a front output and a rear/sub out put. Right now I have the front running to the 4 channel and the rear/sub to the mono. I'm adding a 300 watt mono to power the subs in my doors.
  • Who's Online   0 Members, 0 Anonymous, 947 Guests (See full list)
