I just got my two sa 10s in my car and tried them out. Still need to break in a bit, but for some reason they dont sound noticably louder. I changed the setting on my radio to reverse phase, i think it sounds bette? any ideas? subs are inverted. Should i turn phase on the amp ?
Edit : how can i check that my amp is seeing 1 ohm when i have 2 sets of sub terminals ?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
are your speaker wires crossed at the amp?
Headunit - Alpine 9857
Mids & Highs - T165,T1692
Mids & Highs Amp - T400-4
Subs - 2 12" DC Audio Level 3 M2s
Sub Amp - T1500-1bdcp
Alternator - MechMan 220a
Wiring - 1/0ga XS Power
Batteries - 2 Optima Yellow Tops
Read the fucking manual. Jesus Christ.
I dunno about that Steve...
Chuck Norris doesnt even do push-ups, he just pushes the earth down.
i have the AQ 2200 so each sub has its own power terminal and negative terminal
bump
may be incorrect but I'm pretty sure the phase wouldn't make a difference in your case however your subs may just need to break in a little bit more they're probably still pretty stiff
what coils do you have? has to be dual 1 or 4 or it cant be 1 ohm
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
have you put them non inverted?
make sure your wiring is correct
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
i tried a quick test this morning and couldnt get an ohm reading. i am using threaded rod through my box, could that affect the amp reading the ohm impedance >
make sure it is set on "OHM", pos on red, neg on black
HMU!!!
95 Bonneville SSE
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
