kujos_on24s Posted February 16, 2012 Report Posted February 16, 2012 I recently boughy a rockford fosgate t10001bd (i think it is at least) amp and a memphis car audio 12" mojo how can i tell if the mojo is dual 2ohm or dual 4ohm and how can wire it to its fullest power i know the amp can run at 1ohm so somrone help me out here
IBleedMusick Posted February 16, 2012 Report Posted February 16, 2012 Take a digital multimeter and see what pops on each coil it will not read exactly 2 or 4 but should be close to either number from there if it is Dual 4 you can wire it down to 2 ohms if it is Dual 2 you can wire it down to 1 ohm. 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
kujos_on24s Posted February 17, 2012 Author Report Posted February 17, 2012 How much difference is 1ohm setup
Watch the bass Posted February 17, 2012 Report Posted February 17, 2012 How much difference is 1ohm setup ??? "in the abundance of water, the fool is thirsty" Bob Marley
Hunters21w Posted February 17, 2012 Report Posted February 17, 2012 First make sure the amp is the model you think it is. Then put the dmm to each coil on your sub to check impedance. Then go to the12volt.com and look up the subwoofer wiring wizard. You will see all of your wiring options. 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
