if you RAISE EQ levels after using DD-1 you can clip/distort
if you are using the pioneer in your sig your sub level should be 0, not max
Can you elaborate? Is it different between manufacturers?
what do you need me to elaborate. if you RAISE eq levels you are adding signal, if you set dd-1 to max then add signal you will clip/distort
you dont put sub level on max for every headunit, each one is different. alpines need to be set to max to get full voltage.
this is when a dmm helps so you can see what voltage you are getting at each sub level.
you dont want to go above 0 with pioneers usually, only quiet it from that point. most go -24 to +6.
sub levels/bass knobs are not meant to make a song with quiet bass louder, its better to just know thats how music is, some songs are louder than others and by boosting signal you can easily introduce clipping distortion... especially since not all bass knobs do the same thing.
using loudness will distort/clip the signal, it is not needed. in every manual it is stated to ONLY use it at low volumes
Edited by Decaf
Good to know ^^^^^^^
Bose = Buy other sound equipment.
i love the rattle it's the best part! i need louder cheap amp any ideas?
Well i just re did it with the sub lvl set to 0 and now my amp gain went up to 3/4
2015 F-150 Platnuim
I COULD be wrong about this, but i would prefer to set my head unit to flat so i know my amps are delivering full power
the issue is you don't know when adding sub level starts to distort the signal because every headunit is configured differently
my gain is a bit past half with sub level at 0 on my pio, volume 38 of 40
So what your saying is his best bet is to leave his sub level at zero and set his amp. He can turn it down from there
Still sounds good bass hits a lil harder this way
I just need my new box to be done and for audio savings to have the amp in stock so i can upgrade
2015 F-150 Platnuim
