need new brakes to help my 26'' rims PLEASE!!
I've got ssbc. But I wouldn't say I got off cheap. For fronts only Im at close to 1500. Calipers were a grandidh rotors and paid another three and stainless steel lines another hundred or so. I'll eventually do a new master cylinder and the rears as well so all told its over three grand.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
i been talkin to a guy on tirerack.com and explained my situation, heres what he suggested, will this help at all or will i be in the same boat a year from now if i put these on?
http://www.tirerack.com/brakes/brakes.jsp?make=Hawk&model=LTS+Truck%2FSUV+Pads&group=LTS+Truck%2FSUV+Pads&autoMake=GMC&autoModel=Yukon+Denali&autoYear=2002&autoModClar=
http://www.tirerack.com/brakes/brakes.jsp?make=Power+Slot&model=Power+Alloy+Cryo-Treated+Rotor&group=Power+Alloy+Cryo-Treated+Rotor&autoMake=GMC&autoModel=Yukon+Denali&autoYear=2002&autoModClar=
i know the pic shows 5 lug, but thats just for advertising, he says i will get the 6 lug
so what do you guys think? worth the trouble and money? ive decided to kick it up another $400 for budget, i can do $1000
it will help but its not going to be drastic.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
hey bros, i need some help please, i have a set of 26'' wheels i put on my 2002 yukon denali last year, everything was fine first few weeks, but as expected over time they were just to much for the factory brakes, my steering wheel started shaking as if i needed a wheel alignment which i didnt because when i threw my factory wheels back on in the winter time the wheel shake went away, also when i had my rims on when i would hit the brake the truck would swerve slightly to the right..to the point i would have to turn the steering wheel to the left a bit whenever i braked to compensate for the truck wanting to turn a bit to the left, so my question is can you guys suggest a good set of brakes i can throw on there to help stop these problems but not big enough to where i cant throw the factory wheels back on in the winter time? if possible can something like this exists for $600 or less?
You need the wheels balanced. Have the brake calipers checked out, heavier duty brake pads/rotors.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
I run stock brakes and rotors with 26's on my 01 Denali. Drive it like it's a slow ass truck because it is. If I'm not hard on my brakes I get a year plus out of my pads. I did have a wheel alignment done with my rims on the truck. Some adjustments were needed with the larger rims on because every little bit your alignment is out becomes exaggerated with the larger rims. I'm going bigger with my brakes but other things are more important at this time.
  • Who's Online   0 Members, 0 Anonymous, 1067 Guests (See full list)
