hey bros, i need some help please, i have a set of 26'' wheels i put on my 2002 yukon denali last year, everything was fine first few weeks, but as expected over time they were just to much for the factory brakes, my steering wheel started shaking as if i needed a wheel alignment which i didnt because when i threw my factory wheels back on in the winter time the wheel shake went away, also when i had my rims on when i would hit the brake the truck would swerve slightly to the right..to the point i would have to turn the steering wheel to the left a bit whenever i braked to compensate for the truck wanting to turn a bit to the left, so my question is can you guys suggest a good set of brakes i can throw on there to help stop these problems but not big enough to where i cant throw the factory wheels back on in the winter time? if possible can something like this exists for $600 or less?
For under 600 you're not going to really find what you're wanting. But for 600 you could buy some good cross drilled rotors and some nice ceramic pads which should help. Does it still do the pulling thing when you brake with the stock rims? If so you may want to have your calipers checked out as well.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
no the swerving is gone with the factory wheels..
ask n8, i believe he did upgrade breaks, calipers and rotors when he did the 24s on his pick up truck
i think that was a good option with out going with something super expensive
would you happen to have his full user handle?
I believe he went with SSBC
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Alot of guys will use the brake calipers and rotors from the 05+ trucks. They use a larger caliper and also a 13" rotor. Then along with braided stainless steel brake lines and better brake pads, it helps out alot. This will keep you under $600.
X2
I hate long signatures....
...what the fuck is wrong wiht you you fucking fuckity fuck fuck head...
Mtnbikecrazy55 Feedback
  • Who's Online   0 Members, 0 Anonymous, 350 Guests (See full list)
