fox_racin4 Posted February 20, 2012 Author Report Posted February 20, 2012 finally got a pic! Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Decaf Posted February 20, 2012 Report Posted February 20, 2012 im sure power was a factor, but even with the 2 amps it would do it now and then so i think the added power finished it off it is the sub coloser to the port but all seem to load OK im going to recone and shrink box by a cube or 2 and re try just dont want to do much to the box as i can play almost anything from 30hz-50hz that's exactly what I suspected. It happens because of the difference in pressure in the box from sub to sub and loss of back pressure with the sub closest to port. its always an issue with multi-sub setups and it rears its nasty head the more power you have on tap. does the coil have any rub marks? i can't see any in the pic posted. if no rub marks than you smashed the living crap out of the former... good jorb! Quote
Lbox88 Posted February 20, 2012 Report Posted February 20, 2012 Holy Jesus! You fucked that coil up! Quote UBL | Build Log
fox_racin4 Posted February 20, 2012 Author Report Posted February 20, 2012 Their is rub marks but it was played a bit after that happend as well so Whats the best way to fix this?. The port doesnt bend, just goes straight If i were to bend it so it was an L would that give the subs something to load off? Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
