power... 4 4500s strapped at .7 ( not getting to full tilt becasue of voltage backed off at 12v)
SA10s
subs see 1-1.25 cubes wall is tuned to 40hz
tone was a 39hz tone
only good thing, did a 154.8@39hz!
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Ive seen it happen on vented coils.
If the coil slapped the backplate and buckled at the vents.
Or it is possible that heat builds up to the point where it softens the aluminum former at it's weakest point.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
IIRC SA10s dont "bottom out" the coil cant hit the back plate, the tripple joint hits the pole piece first i believe, But since it broke at highish vomume it did smash the back plate a tad.. It was makin some noise before adding the 2nd pair of amps so i probly just finished it off?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
To many variables with the multiple subs your running I say it was to much power and a loading issue..
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
im sure power was a factor, but even with the 2 amps it would do it now and then so i think the added power finished it off
it is the sub coloser to the port but all seem to load OK im going to recone and shrink box by a cube or 2 and re try just dont want to do much to the box as i can play almost anything from 30hz-50hz
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 1258 Guests (See full list)
